Need help Quick!!
Old Feb 12, 2005 | 11:19 AM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
Need help Quick!!
Hi today I went to replace my rear break shoes after everything was done and adjusted I start the car and begin to take it for a test drive. Now the problem the break pedal is dead hard I mean it’s like when you turn the car off and pump the brakes till it gets hard, hard. Also the car will not stop without pulling the emergency brake! Any and all help is appreciated I need to get this fixed ASAP I have to drive it to work tomorrow and if I cant fix it the shops close at 5 today.
Old Feb 12, 2005 | 12:27 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Well I drove it around the block and the problem went away until it slam on the breaks then it goes back to dead hard for a few min then it returns to normal. My father and me think it’s either not enough vacuum or the break booster. Are we on the right track?
Old Feb 13, 2005 | 03:19 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
That'd be the first thing I'd check...make sure that brake booster vacuum line is plugged in and free of obstructions.
Old Feb 13, 2005 | 03:35 AM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
This has happened to other readers. You should have a little Black Filter in the line ( Looks like a fuel filter ), that goes to the brake booster. Replace it. It's actually an air filter and over time they get clogged. Then you the booster does not recover vaccuum fast enough.
Power Brake Booster Filter
Old Feb 13, 2005 | 01:53 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
The pads will also need to be seasoned before they perform up to snuff, they won't grip that good until they're broken in after a few hundred miles. Read this:
http://www.baer.com/Support/TechTips.aspx?TechTipID=5
Ed
Old Feb 13, 2005 | 02:05 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
I fixed it today it was the way the vacuum lines were routed. We had a few things running off the port in the back the one that suppose to be for the booster. So we rerouted everything so the booster has its own now it works great!
Old Feb 14, 2005 | 03:14 AM
Car: 86\92 Mutant
Engine: 355CI 430HP
Hmmmm...you might want to point this out to certain people who think it's OK to Tee the PCV valve system into the Brake Booster line. I argued against it for exactly the reason you experienced. NOTHING should be Tee'd to the Brake Booster line. Period.
Glad you got it fixed.
Old Feb 14, 2005 | 10:47 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
interesting, guess thats just another among the tons of stuff previous owners ghettoed on my car.
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
