Rotor???
Old Feb 20, 2005 | 08:45 PM
Fcsoldier's Avatar
Car: 1987 IROC
Rotor???
My rotors are glazed over and making making noises so I bought replacements and new pads. The rotors do they slide off and slide new ones on?(I know caliper has to be off and all)
Old Feb 21, 2005 | 08:41 AM
elcamin0_77us's Avatar
Car: 77 El Camino
Engine: 355 Converting to TPI
Transmission: Converting to 4L60/4L60E
Yes, They should just slide off after you remove the "cage" unless they've become frozen on due to corrosion.
Bill
Old Feb 21, 2005 | 09:19 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
If they're for the front, you'll have to remove the cotter pin, castle nut then they'll slide out. Going back on you'll want to check and repack your bearings and install a new seal on the back of the rotor. Then preload your castle nut. A search will get you more info than you'll ever need. Just make sure you've got the seals and grease before you start.
Old Feb 21, 2005 | 10:30 AM
Fcsoldier's Avatar
Car: 1987 IROC
Old Feb 21, 2005 | 08:19 PM
Car: 77 El Camino
Sorry, I guess about 99% of the cars I work on any more are front wheel drive that I don't think about the the rear wheel drives with the intregrated front hub/rotor.
Bill
Fanatic1074
Oct 3, 2022 05:57 AM
loud91rs
Oct 5, 2015 10:05 PM
the_hamturdler
Sep 30, 2015 12:50 PM
the_hamturdler
Sep 22, 2015 02:59 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
