Rear Disc Brake Troubles
Old Feb 25, 2005 | 01:58 PM
black85iroc's Avatar
Car: 1985 camaro IROC-Z
Engine: Lg-4 305
Transmission: t-5 5 speed
so i started replacimg my rear calipers, and pretty much i can't do anything. so im reading haynes and following the steps they go through, and i get to where i have to hold "the lever" and loosen "the nut" and pull off "the lever". i assumed the ebrake lever is the lever they mean, but when i try to pull the nut off it just spins the piston screw. how the hell am i supposed to loosen the damn thing when it just spins?
i'm tired of stuff going wrong and i just want my car on the damn road!
also are these the steps i really have to follow or can i just pull the caliper slider bolts out? sometime haynes gives extra steps but i never know which ones are the extra dumb ones.
thanks, Adam
Old Feb 25, 2005 | 02:21 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
As far as I can remember, you only need to disconnect the brake hose, parking brake cable, and remove the caliper mounting bolts. The only reason I could see for taking the parking brake lever off would be if your replacement calipers didn't come with parking brake hardware already mounted on them, which most of them do.
Old Feb 25, 2005 | 02:29 PM
Engine: Lg-4 305
well mine didnt so i deffinatly need to do that. now i just gotta figure out how!
Old Feb 26, 2005 | 05:24 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
This method may not be "pretty" but it will work. Take a hacksaw blade and make a single cut right in the middle of the bolt that just spins. Make it deep enough to insert a standard screwdriver blade. Hold the center of the bolt with the screwdriver and use a box end wrench to loosen up the bolt from the outside, works every time for me.
Ed
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
