Adding 98-02 Camaro rear disc brakes to 12 Bolt
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
I will buy a Strange 12 Bolt, Strange 3:73 Gears and add 98-02 Camaro rear disc brakes w/12" rotor. Has anyone had a problem with this setup and can I expect a lot of modification to get everything to work with all the hacking of parts. I will bring my backing plate & caliper mounts to Strange next week so that they can build add them during the buildup.
Any advice on this setup will be very helpful.
Thanks: David
Here is the 98-02 brake I bought off ebay:
Thanks: David
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Ed
Ed
What are the RIGHT flanges? Are you talking about the flange that welded on to the the axle?
Went to Strange Engineering website and found that they will accept 98-02 brakes:
Great, you found it...that's what I meant by the right flange, the one that will accept your brakes. I'll be looking into one of those Strange rears for my '70.
Good luck!
Ed
Good luck!
Ed
basically it will be just a plug and play swap. What will be the benefit of changing to a 4th Gen master cylinder over the 3rd Gen cylinder?
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
