front rotor/wheel friction
Old May 2, 2005 | 09:44 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
my driver side rotor/wheel spins with more difficulty than the one on the left side...is there an area or something I can grease on both sides so that my wheels will spin more freely? Thanks
Old May 2, 2005 | 09:47 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Do they spin the same when the brakes are removed?
Old May 2, 2005 | 10:37 PM
Car: 1988 SC Camaro
Engine: 305 TBI
i didn't remove the brakes...i just took off the wheels and spun it around by the studs...i checked the brake pad, i don't think its causing any drag
Old May 2, 2005 | 10:54 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You can take the brakes off to lubricate the guide pins. If they spin different while the brakes are off it might be time to check your wheel bearings.
customblackbird
Aug 15, 2021 10:16 PM
deracer
Apr 11, 2016 12:04 AM
Gambit TA
Sep 1, 2015 07:27 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
