View Poll Results: What brake set up are you running?
C5 Corvette
0%
C4 Corvette HD
0%
C4 Corvette
0%
98-02 LS1 F-body
0%
1LE option
0%
Baer kit
0%
Voters: 0. You may not vote on this poll
Anyone running 18x10 rear and 18x9 fronts??
Old May 6, 2005 | 10:17 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
OK, I need people with brake upgrades to let us know what master cylinder they are running with their set up. We need to know what fits, looks better, and works better. Please also take a moument to take the poll.
Old May 8, 2005 | 01:07 AM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
I have a Strange Rearend w/ Boyd Coddington Signature Series "Hotrod" wheels and 18x10 rear; 18x8 front.My Tire are 245x40-18 front and 285x35-18 rear. The brakes are 2000 LS1 rear disc upgrade. Of course the brakes is enroute to be powder coated, the rims is still in production at Coddington, rearend is still being made at Strange and i'm waiting on the two rear tires to arrive. The front tires are in my garage.
Well that did not answer your question, but post again in a month and I will have an answer...
Old May 10, 2005 | 04:41 PM
irocdan's Avatar
Car: 88 Iroc vert
Engine: 305 tpi. cts-v brakes
Transmission: Tremec T-56
i have the z06 18's all around stock crap brakes for the moment...........
Old May 11, 2005 | 09:32 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I am running the Baer track front kit with the touring rear. The car was originally a 4 wheel disc car, so all I did was install the kit and change the fluid to DOT 4, no problems in 8 years or so.
I am still running stock 16" 91 Z28 wheels; going to 17" probably this year.
Old May 23, 2005 | 07:58 PM
cocacolakidd's Avatar
Car: 84Z & Porsche
Engine: 427sbc - 471 - 850 Demon Claw
Transmission: Bowtie stage II TH700R4 - 10" 3000
Axle/Gears: 9 Bolt w/ 3:45's
I'm running C5 Calipers with LS1 Abutment, and LS1 Rotors set-up front. In the rear I have 1LE Iron Calipers w/11.65" rotors. I have the 98-02 Master cylinder with Wildwood adj. Prop Valve. Stops real good, and the pedal is firmer than it was when I was using a 88 4 disk valve.
I'm still having problems finding E-Brake Cables long enough to fit my set-up, with out Mickey Mousing it. I have heard that the 91-92 E-Brake cables are longer, but I have not tried them yet (To cheep to buy them if they do not fit).
- Ed -
Old May 27, 2005 | 07:29 PM
irocdan's Avatar
Car: 88 Iroc vert
i wanna run the c5 brakes...what do i need to assemble a full set ready to bolt on?
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
