Which factory proportioning valve would be best
Old May 16, 2005 | 01:37 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
In my 1991 I will soon have LS1 front brakes and LT1 PBR's in the rear. My car came factory with the small disc and drums. Should I use the 90-92 1LE or the 90-92 Z28 proporting valve? I was thinking the 1LE since my brakes are roughly the same size, however everyone always tends to want more rear brake pressure so I was also considering the z28 one. Also this is as easy as unbolt the lines and rebolting right?
Old Jun 4, 2005 | 07:09 PM
Car: 91 Camaro RS
Would a non- 1le four wheel disc better than an 1le due to the extra rear pressure? Everyone seems to think that more rear pressure is needed on our cars since they are so front bias.
Old Jun 10, 2005 | 12:45 AM
Car: 91 Camaro RS
TTT, does my question not make sense or does no one have an answer?
Old Jun 10, 2005 | 11:13 AM
NoTransistors's Avatar
Car: '83 Firebird S/E
Engine: The Chevy 305. with carburator
Transmission: 700R-4
I have the answer.
No one has an answer. I understand your frustration. Thousands of members, and not a peep.
Seth
Old Jun 21, 2005 | 10:33 PM
Car: 91 Camaro RS
Or should I just take my stock one and due that screw mod?
Old Jun 22, 2005 | 12:32 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
1LE valve will be the closest match but still far from a perfect match. The LS1 brakes have larger pistons and cylinder sizes. So your best bet would be to install an adjustable proportioning valve.
New2Chevy
Sep 28, 2015 12:35 AM
backtothe80s
Sep 5, 2015 12:39 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
