86 rear discs
Old May 17, 2005 | 11:39 AM
Allan Dollaway's Avatar
Car: 1988 trans am
Engine: 305tpi
86 rear discs
Hey guys, went to change my moms rear brakes and noticed the back of the pads did not line up with grooves or a slot on the small piston??? the rivets were all sheared and everything was wore crooked and lopsided!!! does this sound like a familiar problem? The calipers are rebuilt I know,could the pistons be in the wrong position??? Any help please... Thanks Allan
Old May 17, 2005 | 12:50 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Welcome...I haven't messed with those older calipers in some time, but the pads have some cast "pins" in the back side of the inner pad, correct? If so, you have to screw the piston back in before you install the pads and those pins need to line up with the slots in the piston so they keep the piston straight as it moves out over time. I'd get a piston inserting tool at Auto Zone or the like and try screwing the piston back in and see if this helps.
Ed
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
zayne0
Aug 24, 2015 07:22 PM
