Do I...?
Old May 17, 2005 | 09:36 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Do I...?
Do I need to bleed the front brakes with an adj. wilwood proportioning valve install? I bled the rears and then it got dark out. I'm just curious. I installed the valve in the engine bay btw. For some reason, the directions said to install it at the rear...
Old May 21, 2005 | 06:20 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
I think they say to install it there because it's easier and because if you do it there, you'll not touch the fronts at all. I did mine today in the engine compartment and had to bleed everything because I removed the master cylinder (and put a new one in, but that's beside the point). I'd say you're fine if you didn't disconnect the fronts, but if you did, please bleed them even if you're not having a problem. There could be an air bubble waiting to find a bad place.
LottaBallsCamaro
Mid-Atlantic Region
Mar 30, 2005 01:13 PM
LottaBallsCamaro
Jul 7, 2001 10:17 PM
LottaBallsCamaro
Jul 7, 2001 10:11 PM
LottaBallsCamaro
Jul 7, 2001 03:19 PM
