Drum to LS1 rear disc
Old Jun 3, 2005 | 09:09 AM
98_LS1's Avatar
Car: 87 camaro, 98 Z-28
I've done a search and haven't found what I'm looking for, I found a LS1 rear disc brake set-up for a good price and was wanting to know if it's worth the trouble and how hard is it to convert from drum to disc? I have an 87 camaro which is getting a Wilwood front brake upgrade but I need disc's on the rear, would the LS1's do the job? I heard that the calipers spread but isn't that only the front one's? Thanks,
Mike
Old Jun 3, 2005 | 10:31 AM
OneBadZ4U's Avatar
Car: '86 Iroc, '87 Iroc Vert
Engine: 350 TPI, 305 TPI
Transmission: T5 in both
Axle/Gears: 3.73, 3.45 both LSD's
Did you know there was a Tech article about this?
www.thirdgen.org/newdesign/tech/ls1reardisc.shtml
Old Jun 3, 2005 | 10:56 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
That link did not work, try this
LS1 rear brake upgrade
The swap is real easy and worth it in my opinion.
Old Jun 3, 2005 | 12:01 PM
98_LS1's Avatar
yeah, I just found it a minute ago, thanks though! I've allready located the parts so hopefully this weekend or the next I can get started on it
Orr89RocZ
Apr 25, 2016 08:28 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sailtexas186548
Jan 19, 2016 12:21 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
