Rear Brakes - LS1 vs 1LE
Old Jun 22, 2005 | 07:12 AM
zimmstoy's Avatar
Car: 85 Iroc
Engine: 305 LB9
I have already performed a search and found a wealth of information on front brake swaps.
Here is my questions.
I have 1LE Rear Brakes on my 1987 GTA. I swapped them on about a year ago. I recently picked up a 1991 Formula that is said to have LS1 Rear Brakes on it.
I have looked at both setup and they look 100% identical to me.
Is there something I am not seeing here? Is something different?
Any information on this topic would be greatly appreciated.
Old Jun 22, 2005 | 09:20 AM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
If they are identical they are probably PBR's, which are a quality rear brake setup.
Old Jun 22, 2005 | 09:22 AM
zimmstoy's Avatar
Car: 85 Iroc
Engine: 305 LB9
They are both PBR Brakes.
I just want to know if they are truly identical or not.
Old Jun 22, 2005 | 10:14 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
the "LT1" rear brakes are identical to the late 3rdgen PBR brakes...
the "LS1" rear brakes are totally diffrent. they are larger, look diffrent, and require massive grinding to fit drag wheels on...
personally, i like the "LT1" brakes better.... but im a drag racer, and i dont like grinding my calipers to fit my rims.
Old Jun 22, 2005 | 10:21 AM
zimmstoy's Avatar
Car: 85 Iroc
Engine: 305 LB9
So if it is indeed an LS1 rear brake, it should look totally different?
Anyone got pics of what an LS1 rear brake should look like?
Old Jun 22, 2005 | 10:28 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
pics here: https://www.thirdgen.org/newdesign/t...reardisc.shtml
Vintageracer
Jan 10, 2020 05:33 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
