disc brake swap
Old Jun 26, 2005 | 02:13 PM
355gta's Avatar
Car: 1989 pontiac firebird trans am gta
Engine: 355
Axle/Gears: 327:1 9 bolt
disc brake swap
I have an 89 GTA with a nine bolt. I am buying a 10 bolt that is rear drum and I need to know if the proportioning valve off of the nine bolt will work on the ten bolt. I also have a post in parts wanted looking for the caliper brackets for the ten bolt so if anyone has some please check it out.
Old Jun 30, 2005 | 08:38 PM
355gta's Avatar
Engine: 355
Is there no one that can tell me. I was hoping to get at least one reply. Thanks any ways.
Old Jun 30, 2005 | 09:54 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You're swapping the brakes over, right? The prop valve will then match the brakes so you will be fine....the prop valve will have nothing to do with what type of rear you run, only the brakes.
Ed
What caliper brackets do you need?
Old Jul 1, 2005 | 09:42 PM
355gta's Avatar
Engine: 355
I need the caliper brackets for a ten bolt.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
