conversion from drum rear to disc rear
Old Jul 9, 2005 | 09:56 PM
blackroc68's Avatar
i swapped the rear from my 1988 transam to a 1988 disc brake 9 bolt changed master cylinder and proportioning valve the lines from the master cylinder to this valveare the same as the original. but the bottom 2 are much larger. anybody know how i can install it .is the ile valve diffrent all lines match up accept the two on top going to the master. any help is appreciated.
Old Jul 13, 2005 | 07:49 PM
Parrydise7's Avatar
Search for posts by ebmiller88 on this. IIRC this is the guy that has this sorted out.
Old Jul 19, 2005 | 08:59 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
The top lines dont' match up? My advice would be to change out those lines with a set that do work, all masters have the same threads so they'd be sure to work. Just pick a car at a scrap yard and see what works.
Ed
Orr89RocZ
Apr 25, 2016 08:28 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
