C5 Upgrade Parts
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
C5 Upgrade Parts
I'm upgrading my front brakes to Z06 Corvette upgrade. I already have Calipers, rotors, and calipers mounting bracket. Where is the best place to buy the modified spindle and hub to complete this setup. Also, are there any other parts that I need that not mention above accept for the disc pads? I have 18' Boyd Coddington "Hotrod Wheels", so clearance will not be a problem.
Car: 1992 Jade Green---Trans Am Converti
Private message TPI383... I got mine from him and was very pleased. He can do the hubs and adapter brackets. The spindle is very easy to modify yourself. Other than bolts, you should be good to go.
Kevin D.
Kevin D.
LT1Formula
20
Nov 14, 2015 12:02 AM
