which e-brake cables?
Old Sep 1, 2005 | 03:45 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
I have an '88 IROC with drum brakes. I'm in the midst of doing a swap.. I've got a 10-bolt rear end w/ 3:73's and drums sitting on my shop floor. I've also purchased the rear disc brakes off a '96 TA (PBR Calipers, rotors, backing plates, etc) I'm going to put the two together, it doesn't seem like it will be overly difficult.. however which e-brake cables do I use?
DO I use the '96 TA e-brake cables (still attached) or the original cables from my IROC which I don't suspect will work since they're for drums. Do I need to purchase some cables from an 89-92 car which had discs and PBR's?
Thanks for the help... a part number would be a bonus too.. but I'll assume that any aftermarket parts store would have this item?
Old Sep 2, 2005 | 06:21 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
This link will provide the p/n you're looking for:
https://www.thirdgen.org/techbb2/sho...hreadid=246768
JamesC
Old Sep 2, 2005 | 02:32 PM
Brisk's Avatar
thanks, thats exactly what I needed...
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
