Couple brake questions..
Old Sep 21, 2005 | 11:29 AM
zrated383's Avatar
Car: '88 IROC-Z
Engine: StealthRammed 355
I have an 88 IROC w/4 wheel discs. I have two problems. One is that there are two grommets that go in the caliper where the mounting bolts go. For some reason they are missing on one of the calipers. Therefore, the caliper moves slightly causing a high pitched squeaking noise when I hit bumps, etc. Another thing is, when I apply the brakes then let off I hear a click. I believe the sound is coming from the same wheel. Is this coming from the same problem? Thanks.
Old Sep 21, 2005 | 10:19 PM
The Wizard's Avatar
Car: '85 Z28
Engine: 355
Transmission: TH350
You can buy a bolt kit at you local parts strore that comes w/ those bushings and grommets. I got mine at carquest.
Frozer!!!
Jan 19, 2024 04:55 PM
tealman92
Exterior Parts for Sale
Aug 27, 2015 11:21 AM
kyleb24
Aug 15, 2015 08:24 AM
novaderrik
Aug 10, 2015 12:44 PM
