Brake Booster Rod Height
Old Nov 7, 2005 | 07:04 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Transmission: gto t56 (mn12)
Does anyone know a good way to measure brake booster rod height. There is an adjustment inside the car where the pedal is. And also a metal rod sandwiched in between the master cylinder and the booster. I cant find any specs anywhere for proper length. Any help out there?
Old Nov 8, 2005 | 08:32 AM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Does anyone know what I'm talking about?
Old Nov 8, 2005 | 10:41 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Hell no.
There is no adjustments on my brake booster rod. I havea brake booster in piece right now. And that other rod is a set length, no adjustments.
If your has adjusters, your looking at the wrong part or have special parts not factory.
Old Nov 8, 2005 | 10:11 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
The rod that connects to the brake foot pedal is threaded. So when you turn it one way the length increases then when you turn it the other way it decreases. I didnt know what factory specs are but maybe your're right maybe its not the right one.
Old Nov 8, 2005 | 10:27 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
my 86 doesn't have that.
customblackbird
Aug 15, 2021 10:16 PM
gixxer92
Sep 1, 2015 04:32 PM
zayne0
Aug 24, 2015 07:22 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
