Guys with GTA wheels, get in here...new brakes! Merry Christmas!
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
but if you correct the suspension, so the rear doesn't pull the wheels up under braking, you don't get a chance for hop.
IF, it was just locking up the brakes, that would be one thing. The hop is caused by the changes in braking torque on the rear, causing the problems.
What is happening here, brakes are applied, the initial torque on the rear axle is high, because there is traction, this interacts with the intant center. the anti-lift and anti-squat work here, causing the rear to lift, this gives less braking toque, when that gets low enough, there isn't enough braking torque, cause the rear to drop until it gets traction, raising the braking torque, cuasing the rear suspension to lift again. Its a cycle.
If it was just a matter of weight transfer forward, then you would have rear lock up issues, the hop issue is one of the rear geometry being wrong.
I keep preaching to everyone why I run progressive rate rear springs to induce some squat but the rapid increase of spring rate keeps the car from brakehoping under extremem rear braking forces- It why I can run the car with high rebound settings and a 25mm rear bar.
Guys, first of all, thanks for all the valueable info.
Ok, here's the short version of where I am at right now:
Last season, I had help with designing the geometry of a third link setup. I have everything installed on the car as far as the body side goes and have been stuck on fabricating the pickup point on the rearend. I found a 1/4" steel fabbed rear cover (Dana 44) and have fabricated a mount/pickup point which is welded to it (integral part of the cover). I hesitated using it last year because I was afraid of the the stress it would put on the cover studs since they are only 5/16" and there is only 9 or 10 of them (can't recall now). I am currently working on a brace that will at least make me more comfortable with trying the third link out.
Anyway, here is a drawing of how the geometry will end up when fhinished (the seemingly randomly place planes are bodywork and such that cannot be passed through):
This is what I'll end up with if and when I get this 3rd link installed. Thoughts?
-Jeff
-Jeff
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
Just thought that I would mention that Unbalanced Engeneering sells a kit that can lower both sides of the phb. Lowers the roll center and keeps the bar level.
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Originally posted by Julie Bergman
Hi Ed,
Will your new Wilwood set-up work with Formula wheels? I am trying for a stock look on my '91 Formula street car. I am really curious and excited to hear about this as I race CMC, have been racing with a 3rd gen Firebird with the 12" Baer brakes set-up. I have never had any complaints about the braking or unusual wear with that set-up. I was planning an LS1 brake conversion for my '91 Formula, I think this changes my mind! What is the best way to keep updated on this kit?
Hi Ed,
Hi Julie..I'm sure it will fit those wheels but I won't have the setup back together for a few days, the brackets are getting finished. I'll keep you all updated as I progress, I'm close but I'm just waiting on parts now. Plus I just got really busy at my real job so I'm pressed for time as well.
Thanks for your interest.
Ed
-Jeff
-Jeff
https://www.thirdgen.org/techbb2/sho...62#post2681662
No problem Dean, good reading.
Now....
Update on this kit: I hope to have final fit up pics up over the weekend. The real job is keeping me busy at the moment (It's 2 AM and I'm at work) but I'll get it done.
Thanks for giving me my thread back.....
Ed
Now....
Ed
Car: 91 Formula WS6
Transmission: five speed
Cool Ed, Does the kit come with a case of Corona light? Saw it in one of the pix!
Seriously tho, I am very excited about this set-up!
Seriously tho, I am very excited about this set-up! Thread Starter
Seriously tho, I am very excited about this set-up!Ed
Car: 91 RS
Looks good so far eb
This looks alot like Chickenman35's setup from a couple years back.
How improved should these be over the 1LE setup other than a weight reduction?
Just wondering how much the 4pots would improve the brakeing over the 2pots
They should perform better than a 2 piston caliper due to the opposed piston design. Ask guys who run them, I'm sure they'll have a more informed opinion than I would. Remember, I don't run these brakes...I only make them...
UPDATE: Brackets are done and back from the plater. Here's some assembly pics. I still have to do some lockwiring on the bolts and the rotor hats but other than that it's good to go.
Enjoy!
Ed
Enjoy!
Ed
This is how the bracket looks when assembled. The spacers locate the caliper over the rotor:
Hubs now installed, Timken bearings and ARP studs:
Here's the back view once the rotor is installed. Its' tight and I clearanced the bracket to clear the inside of the rotor just in case:
Done with this setup, on to the next:
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
I rely on the added track width (5 or 6 mm) of the 1LE brake assembly to keep my ROH wheels from hitting the outer tie rod. Does the rotor hub provide that additional track width like the 1LE package?
I use a standard hub here since the aluminum hat is .500" thick. The 1LE hub is .318" taller than the standard hub so this design would give you .182" more track width than the 1LE rotor does, plenty for your needs.
Ed
Ed
Cool deal, Ed!
I think then,
that I want to put these brakes on my Trans Am in time for NFME at Indy in May. So, how about we look at getting something ready for delivery first week in March? PM me a price (without spindles, since I already have modified ones) and an address to which I need to send the money order. I should be able to put the check in the mail on February 25th. ZIP code 48840, residential address.
The car's in the air right now getting it's new rear suspension, including a new Moser 12-bolt and I've got a lot of welding to do between now and then to finish off the decoupled torque arm installation.
I think then,
Will do, I plan on making that event also but I can't find the link to it and I haven't been on the F-body mailing list in forever.
Ed
Ed
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
ebmiller, You are going to get me put in the dog house!!!!!! I just put an LS1 conversion on last summer, but after looking at this and seeing how easy it is, I would be afool not to upgrade
Let me know when your going to sell some stuff.
Let me know when your going to sell some stuff. Thread Starter
No problem. I'm getting brackets made now so I'll keep you updated.
Ed
Ed
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Wow, I wish I had seen this thread earlier. Lots of good stuff in here. I do have a question though.
Ed & 36ASedan: do you guys think the small (stock) outer wheel bearing will last up to the abuse of an AS car? Wheel bearings are cheaper consumables then brakes, but still something I wouldn't want to have to change all the time.
nape, AFAIK, many of the guys in AS run modified std spindles with no issues. Most of the bearing issues I've heard of are related to use with aluminum hubs. I have been running 1LE spindles and bearings until now so we'll see I suppose
. Thread Starter
I don't expect the outer bearings to be an issue. Good thing they aren't that expensive should you need to replace them. You could run a 1LE hub with rear wheels on the front to put yourself a bit more at ease but that would add just a bit to track width.
Ed
Ed
Ed
Ed
Ed, to make that switch you would just have to increase the spacers that are welded onto the brackets in the picture you posted earlier, correct?
TIA,
-TJ
To use the 1LE hub, it would actually be a decrease in the spacer thickness since the caliper would be moved out. Or, now that I think about it, I could use a rotor hat with a deeper offset to make up for that added outward push of the 1LE hub.
Ed
Ed
Duh, you're right.
I need to stop posting before I have a cup of coffee...
After looking at it, it won't be too far a stretch to make the 1LE hub work, just a different hat with the overall offset close to what I have now.
Ed
Ed
Car: 91 GTA
Engine: 377ci
So how are those brackets coming???? I Have some cash burning a whole in my pocket right now. I would like nothing better than to help out the local car guy community
I have 5 pair available but I'd need time to "tailor" them to the spindle and caliper. Also, would you want a set for a 1LE hub or standard hub like I used in Jeff's kit above? I can do either.
Ed
Ed
Car: 91 GTA
Engine: 377ci
Well I am using a hub that I machined down out of stock 10.5 rotor. I am using it to hold an LS1 rotor that is 12.75 in diameter and 1.25" thick. So I am not sure where that lands in the scheme of things. I am also using LS1 brake calipers. By LS1 I mean the 98 and up F-body chassis.
Hmmm...OK. So you're essentially just wanting the brackets? If that is the case, there's a whole lot of issues with your setup as you described:
-You're using LS1 calipers, they won't work with these brackets;
-"LS1" rotors are 12" x 1.25"...are you using C5 rotors which are 12.75" x 1.25"? That style rotor will probably require a spacer to keep the wheels from hitting the calipers (Wilwood);
This won't be a direct install using the parts you listed. Can you elaborate a bit?
Ed
Ed
Car: 91 GTA
Engine: 377ci
Yea,,,, I was pretty vague. I am using a C5 rotor. I am also using a ROH 18 inch wheel.
What I was hoping to do was buy the bracket/rotor/caliper and fit it to my spindle.
OK, gotcha now..do you plan on running spacers to get the wheel to clear?
Ed
Ed
Car: 91 GTA
Engine: 377ci
That would kind of be a deal killer for me. I spent a good bit of money on the Drift R Wheels to get away from spacers, as this car is regularly autocrossed and hopefully soon,,, will be spending time at Road America.
I know the debates that are being had about spacers and no spacers, but for simplicity sake, you can put me in the no spacer crowd, right or wrong as it may be.
So would I have to use spacers? The Drift R's make the brake combo I am running now look small. I have not had any problems on the autocross courses, but I am a little leary of running road courses with my current set up. Also the current setup gets a little squirmy when coming down from high speeds,, like the quarter mile. I have played with the caster, toe, and camber in that order, with limited success. I am wondering if it is a break pressure issue?
Anyway I will quit boring everyone with my problems and see what you have to offer. Thank you for your quick informative replies.
That's why I asked...and that's why I used a 2 piece rotor with a heavy hat offset. The C5 rotor is a flat rotor with little offset. I had to use a tall rotor so I could stay away from using a spacer and push the caliper to the inside, giving me plenty of room for the wheel to clear. IMO, unless your wheels have a large amount of hub offset, you cannot use just a C5 rotor for this setup, it throws all the measurements off and the wheel won't clear the caliper. Now, if you want a 13" x 1.25" rotor or even a 14" rotor if you want to go that big (14" = big money), I can look into those as well. It wouldn't be a far stretch do to that.
Any reason besides cost that keeps you with the C5 rotor?
E
E
Car: 91 GTA
Engine: 377ci
I am not stuck to the C5 rotor. I am under the impression that is what is on my car now, but maybe not.
I am interested in the rotors you have in your first picture, as long as they are not entirely to pricey, as i have a bad habit of using wrong brake pad compounds when I am in a pinch. As you know this usually leads to early rotor replacement
You'll be glad to hear that I've learned of another rotor I can use that is close to the C5 in size so I'll keep you posted, I just have to find a vendor in the US. I can't tell which rotor you have by the pic, no way for me to tell what's behind the wheel.
The two piece rotors I used will run you $260-325 IIRC for the pair including hat hardware, depending on which rotor you use.
Ed
Ed
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
This set-up is really sweet. I have totally stock GTA brakes, and they SUCK! What would I need to do/buy to do this conversion?
If you haven't already, send me a PM and I'll fill you in.
Ed
Ed
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Originally posted by Mongoose
You can run rears up front with the C4 kit if you use a .25" spacer. I had a post about this sometime back right after Ed and I put the brakes on my car. The rotor in addition to the spacer brought the rear wheels out to where the fronts would have sat on the OE brakes. With the .200" extra from the rotor hat it should be close enough to work without problems.
What if I am not concerned about getting the rear wheel to sit exactly where the front wheel would have. In other words will the rear wheel positioned up front on the new c4 brake kit clear everything WITHOUT the spacer ?????
Originally posted by Jetmeck
Goose,
Goose,
Ed
Originally posted by RMK
Assuming a 12 inch rotor, how much better are the brakes with the 4 pot Wilwood caliper compared to say, a two pot C4 or LS1 caliper?
Ed
Hi Robert..4 piston calipers will exert more clamping force since there's force of the pistons on both sides, not just one. Again, I don't run this kit or one like it but maybe a few guys who do can post with their opinions on how they perform.
Ed
Ed
-Jeff
Originally posted by DM91RS
Jeff if you don't mind the question what tracks do you run on other than the runoffs which IIRC are moving away from mid-Ohio?
DM
DM
I did not run the Runoffs at Mid-O. This year will be my first Runoffs (hopefully) which will be in Topeka at Heartland Park (HPT). I have been running Regionally in the Midwest Division of the SCCA for the past two years. I managed to win the Regional points race both years and even received the Rookie of the Year award for 2004. However, there is not a lot of Regional competition so it was not as big an accomplishment as it sounds. I live less than an hour away from HPT so if I can't do it now I probably never will.
Besides HPT, we regularly run at Hallet, Gateway in St. Louis, Memphis, and Mid-America in Iowa. It looks like we'll be going to the June Sprints this year at Road America but I will most likely not be bring my car (I also am the crew chief for Mike McGinley who runs a T1 Z06 and a CSR Radical SR4). I stay VERY busy
