grand am w/t ws6 brakes pak
Car: 91 ws6
Engine: ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
Transmission: TRANSMISSION, MAN 5 SPD, B0RG WARNE
Axle/Gears: AXLE REAR, 3.42 RATIO
using spindle for suking air truh weel
am planig to to suk air truh the weel and vented disk ther for my weel will stai clean
spindle to be mod with a fan or negative pressure with front air
input of the nose car 91 formula
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
You want to create some sort of ventillation at the discs so that air will blow through and keep brake dust from building (and also cool the brakes better)?
Sounds good. How exactly were you going to do it?
Car: 1992 Jade Green---Trans Am Converti
http://www.skulte.com/index.php/cPat...e2825b6349c5c2
Here's a brake cooling kit. Anything ran to the front will blow air on the rotors, not 'pull' dust from them.
In other words, your idea won't work. I highly doubt that you would be able to rig up anything to pull enough, brake dust is very fine and goes everywhere.
Kevin D.
Kevin D.
Car: 91 ws6
close
Yes that the idea for blowing in I wont to blow out or suck out
dbrochard
Sep 19, 2015 08:13 PM
