rear brake calipers
Old Feb 7, 2006 | 11:28 PM
rleprechaun's Avatar
Car: 1987 TransAm
Engine: 350 Goodwrench
Transmission: 700R-4
rear brake calipers
I have a 1987 Firebird. I am converting from rear drum brakes to disk brakes. The rear axle and brakes are a 7.625 10-bolt from a 1985 Chev. IROC. I installed new rotors and pads. The calipers were locked up. I purchased remanfactured calipers. The problem I am having is I can't get the pistons to push back on the new calipers. HELP, any suggestions would be appreciated. I have a caliper piston pusher. It will not move the pistons. The brake lines are not attached.
Old Feb 8, 2006 | 08:49 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
On those old style rear calipers the pistons have to be turned to go back in, they don't just push back in. Note the holes in the outer edge of the pistons, this is how the rotation tool fits the pistons. You can rent one at Auto Zone or the like or just use a pair of needlenose pliers to turn them back in. Good luck!
Ed
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
