anybody try these rotors?
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
Well im looking at parts to upgrade my stock brakes instead of buying oem replacement parts i was searching for better rotors and found some slotted rotors (should i get slotted or drilled?). I dont want to swap rears for 4 wheels disc brakes or spend alot on brakes just wanted something alittle better then stock. Also do they make any upgraded drums, calipers, wheel cylinders if there is such thing as better wheel cylinders, or ceramic brake pads or better shoes you all know of would be great.
slotted rotors
slotted rotors
Car: 84 Z28 / 91 Trans Am
Engine: LS1 / 5.0 TPI
Transmission: T56 / 700R4
Axle/Gears: 4.09 / 2.73
power slot makes good rotors i have used them on alot. ssbc makes twin piston front calipers to replace the stock single piston iron units. get a set of hawk or performance friction pads pads. upgrade the hoses to braided lines. thats about all you can do and still use a basically stock setup.
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
From all that i have read, slotted rotors are a better bet for the street. the slots help escape the gases and clean the pads. for drilled rotors. they help with the gases also but have a tendancy to crack right around the holes.
the_hamturdler
Sep 30, 2015 12:50 PM
the_hamturdler
Sep 22, 2015 02:59 AM
