baer brake questions
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i was wondering if anyone here has ever bought this kit. what did you think of it. did you have to modify the spindle. is it worth the money or not. thanks for any help.
http://www.thunderracing.com/catalog...vid=6&pcid=145
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Please specify which kit..the link goes to the front kit page and doesn't show just one kit. If you are referring to the 13" Track kit, I know some guys on here run that kit. I've heard only good comments on Baer's stuff. The only exception is that their rotors are very expensive, but IMO their kits are over priced...I can build you a 13" x 1.1" C4 HD kit with braided lines, zinc washed and drilled/slotted rotors for $1000 all day long.
Ed
Ed
Car: 84 camaro Z28
Engine: 434sbc
yeah i was looking at the 13inch front kit. i was just looking at all my options. im probably going to buy from you ebmiller. also how long does it take you to build and send out your kits. ill be looking to order from you real soon
The quality of the kit is excellent, the rotors are pricey but very well built and they last. you get everything you need in one shot and they work. keep up on the pads and you will be just fine. i have 20,000 miles on mine and they look the same as the day i installed them.
i am currently thinking replacing my 2 piston track setup with their alcon 6. i would only recommend the track kit with the 2 piece option as otherwise in the looks department you can get the same performance/looks out of other much cheaper oe units.
ed has been around for quite sometime, if you need help he's the one to talk to.
