Finished drum to LS1 rear discs conversion
Old May 3, 2006 | 01:09 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Finally did my rear drum to LS1 disc conversion. Here's some pics for those curious. Just a sawzall and a drill, couldn't have been much simplier to install. Have 1LE brakes up front so I used the 1LE prop valve and Valvoline Synpower fluid. Front and rear both using Hawk HPS pads. During testing, the rears will lock up first on dry pavement, so I'm going to try a more aggressive front pad. First though I'm going to try my Random Tech torque arm so see if that has any affect on the rears.
Attached Thumbnails Finished drum to LS1 rear discs conversion-drum2disc6.jpg   Finished drum to LS1 rear discs conversion-drum2disc8.jpg   Finished drum to LS1 rear discs conversion-drum2disc9.jpg
Old May 3, 2006 | 07:07 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Did you use the backing plate for a template for the holes?
JamesC
Old May 3, 2006 | 12:56 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Arent the calipers supposed to be trailing?
Old May 3, 2006 | 02:47 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
LS1 rear brakes are more often leading due to the e-brake cable routing.
Ed
Old May 3, 2006 | 05:02 PM
Speedy Mike's Avatar
Car: 92 Firebird Conv
Transmission: T-56 w/3.42 Posi
i just did the conversion to ls1 brakes friday, they are awsome!!
Old May 4, 2006 | 03:39 AM
JamesC
Yep. Used a c-clamp and used the lower 2 drum backing plate bolt holes as a guide to center the disc backing plate before drilling.
Nope. Factory LS1 calipers are leading, but can be positioned either way when modding the drum axle. I chose to use the factory brake line and ebrake bracket which mounts to the LCA axle bracket so I had to make them leading.
Last edited by Justins86bird; May 4, 2006 at 03:43 AM. Reason: Automerged Doublepost
Orr89RocZ
Apr 25, 2016 08:28 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sailtexas186548
Jan 19, 2016 12:21 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
