LT1-LS1's
Old May 20, 2006 | 09:16 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
LT1-LS1's
Going to do rear swap and had did some searching and wanted to know if the LT1's where just as good as the LS1's? Going to put Ls1's up front and after reading some posts unsure about LS1 rears.And where the LT1's dual piston calipers? Thanks in advance
Old May 21, 2006 | 03:30 PM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
LT1 rear brakes are just as good as LS1 to the point where you will probably never notice any difference except for that LS1 do have better emergency brakes though, are you doing the whole axle or just brakes? i had a choice of Lt1 and Ls1 and decide for lt1 for the ease of installation of rear emergency brake cables
Old May 21, 2006 | 03:58 PM
Car: 1992 camaro
Axle/Gears: 3:73
Thanks Just going to do the brake's for now. So where they a direct bolt on? herd some say the was some said there not.
Old May 21, 2006 | 06:48 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
LT1s are a direct bolt on right down to the e-brake cables, where the LS1s are not. Personally I'd go with the LT1s for that reason alone, they will give you plenty of rear brake.
Ed
BLACK ICE
Sep 9, 2006 07:46 AM
1BADROC
Jan 17, 2006 07:07 PM
