"squishy LS1 rears"
Old May 24, 2006 | 08:17 AM
Tricked-Out-Toy's Avatar
Car: 91 Z28
Engine: Lt1
Axle/Gears: 3.70 auburn pro 9"
"squishy LS1 rears"
hey guys I havent been able to swap the C5 brakes in the front yet so all i have is the stock fronts on my 91 with LS1 rears. I also have the stock master and prop valve. I was wondering if anyone noticed the ls1 rears being "squishy" they dont seem like they are getting enough brake fluid OR I have to bleed them some more. Im thinking its since I dont have the C5s up front the stock front brakes use less fluid than the rear LS1s therefore when i hit the brakes the fronts "maxout" before the rears get enough fluid. Am I looking at this right?
Old May 25, 2006 | 08:14 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
I was about to post a question that has to do with your question. The LS1 rear sounds real nice, but I was unsure how 10.5 inch rotor brakes in front and 12 inch rotor brakes in back would drive .
I hope you get your squishiness resolved.
Old May 25, 2006 | 08:18 PM
Car: 91 Z28
Engine: Lt1
ya me to I havent been able to find the time to re-bleed the brakes yet but ill post here when I figure it out.
Old May 25, 2006 | 10:07 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
GM built a ton of these cars with big disc brakes on the rear and small discs on the front. The Formula I had and the one I have now both came that way. I put 1LE brakes on the front to improve my braking.
Old May 26, 2006 | 06:22 AM
Car: 91 Z28
Engine: Lt1
Ok so caliper size doesnt matter? I was just thinking if the prop vavle was designed for a smaller caliper in the rear, it wouldnt be able to "fill" it before the front went tight. idk ill be fixing it either way as soon as my damn C5 brackets get here!
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
