Bad Brake Hoses
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Bad Brake Hoses
Thought I would pass on some useful info.
My car has been pulling to the right slightly & the right wheel showed more brake dust, so I thought it was caliper time.
Tossed on a right caliper & started bleeding the brakes only to hear the fluid squeel as it came through the brake hose. The hose was internally collapsed & holding fluid pressure on the caliper. The caliper was fine.
Tossed on a new hose & thought it would be fine. Now it pulls really hard to the right....... The left hose is collapsed as well & now the right side gets more pressure (due to the new parts) causing it to pull.
Obviously, you should change them in pairs, but due to time constraints (& customer cars filling the garage) , I did 1 side at a time (outside between rain storms) only to find out the good side was actually bad as well.
At least $10 rebuilt calipers (with hardware) & $16 hoses aren't that bad.
Hopefully this may help someone on their next brake job.
Sorry... had a brain lapse & posted it in the wrong forum....
Lonnie Pavtis
Lonnie Pavtis
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
same deal happened to mine a few months ago.. car pulled insanely hard to the left, and i was told that it was the brake hose swellinginside of itself.. or internally collapsing. fluid not getting back to the master
but now i jsut went wild and had Ed milller build me some brakes, when i could have jsut got some new brake hoses.. i;'m sure ill enjoy my new C4 brakes much better though
Car: a car being parted out
Engine: blown up
Transmission: in peices
1992 Trans Am
May 10, 2023 07:19 PM
