HELP!!! wtf is going on.
Old Aug 1, 2006 | 11:04 PM
carbed87's Avatar
Car: 1991 t/a black on black
Engine: 350 tpi
Transmission: 7hunR4
when i went to bleed my brakes the banjo bolts were leaking on both sides. this makes me mad cause i had replaced both the hoses and calipers, but neither of the kits came with new banjo bolts. not to mention when i was pulling everything off the banjo bolts had no washers on them. so when i put everything back together i tried both: with and without washers, and still no avail, the thing still leaks. what should i do!!!
Old Aug 1, 2006 | 11:10 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
you need new washers, and one on each side of the line fitting. It should go like this: caliper, washer, brake line fitting , washer, banjo bolt. Good luck!
Ed
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Did you use new crush washers, or did you try to reuse the old ones?
Old Aug 1, 2006 | 11:11 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
new copper washers
if they still leak with those on then i would be very stumped
never seen or had or heard of them leaking, ever
thats pretty crazy,
also i never replace the bolts with new ones
never have any problem at all with original bolts
so hum
odd...
it has to be a washer problem or wrong bolts or something else
good luck
Old Aug 2, 2006 | 12:40 AM
carbed87's Avatar
Engine: 350 tpi
so i tried it without the washers (new copper ones) and they seemed to have held up so far. i didn't have my friend with me so i couldn't bleed them and tell for sure. but they look like they're holding up. i gues we'll find out tomorrow when i try to button everything up.
so i'll give an update tomorrow guys thanks!
Bubbajones_ya
Oct 25, 2015 08:01 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
racereese
Oct 3, 2015 03:46 PM
sjorgens
Oct 1, 2015 07:54 PM
