82-88 disc rear - convert to LT1 brakes?
Old Nov 16, 2006 | 04:34 PM
c4racers's Avatar
Question - I have an early disc brake rear - 10-bolt.
Can I swap brakes from an LT1 rear? I don't care about parking brake as this is a race car. I also heard I could use C4 rear brakes - I might even have a spare set laying around from my C4 days, I need to look.
What is involved in the swap - is it complete bolt-on? Just swap the backing plates to the 89-92 10-bolt ones, swap the hardlines as needed, and the calipers themselves? Anything else?
Old Nov 16, 2006 | 04:45 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Hey, c4, welcome to the site. You'll find that there's a wealth of info here; consequently, a search is always a good thing. You might start with this link for example:
https://www.thirdgen.org/forums/brak...backing+plates
JamesC
Old Nov 16, 2006 | 05:03 PM
c4racers's Avatar
I did a search, but it wasn't completely clear to me.
So these backing plates will bolt directly to a 82-88 disc brake 10-bolt and allow the pbr caliper mounting:
Note the 10-bolt backing plates, available from GM (P/N 10136853 and 10136854).
Just double checking if I got that right.
Old Nov 16, 2006 | 06:08 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
I just got through installing a set of LT1 disc brake rears on my 40 Chevy that has a 10 bolt 73 Nova rear, and it was truly a piece of cake.
I turned the axle hubs down so the rotors would slip on and the rest was bolt on. No shims or anything. My rotors are centered in the abutments just fine.
Maybe I was just lucky.
The ebrake cables are pretty easy to work out also.
The weights had to come off the calipers to clear my leaf springs.
The threads are wonderful on TGO if you take the time to read through several of them. Then a little common sense and you can do your job.
Old Nov 16, 2006 | 06:24 PM
JamesC's Avatar
I have no experience with the LT1 backing plates; however, the 89-92 plates will accomodate the LT1 PBR calipers, which are essentially the same as the 89-92 PBR's.
JamesC
Old Nov 17, 2006 | 06:22 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I have all the rear conversion parts on hand if you need anything from backing plates to banjo bolts, LMK.
Ed
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
