Drums-4th gen Discs
Old Dec 15, 2006 | 09:31 PM
Yellow87Cam's Avatar
Car: 1987 camaro
Engine: 6 cylinder
Transmission: 5-speed
Drums-4th gen Discs
hey whatsup,
I have a stock rear end in my 87 camaro and i have drum brakes and i was wondering if i do the 4th gen rear install with the disc brakes what will i need to do to set up the brakes? I dont know much about rear ends or brakes so im looking for as much help as i can get.
Thank you,
Nick
Old Dec 15, 2006 | 09:41 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
If you use the brakes from a 93-97 you can use third gen(89-92) parking brake cables.
If you opt for the LS1 style then you are on your own to figure out the cable issue. You will also need a third gen proportioning valve for a rear disk car.
Old Dec 16, 2006 | 05:36 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Or you could modify the axel flanges on your 87, then use 89-97 PBR's. As bingo points out, the e-brake wouldn't be an issue with that set-up. FYI, the fourth gen rear is 4 inches wider.
Here's the idea behind the axel flange mod:
https://www.thirdgen.org/ls1reardisc
Once that's done, here the PBR set-up:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old Dec 16, 2006 | 09:45 PM
Car: 1987 camaro
Engine: 6 cylinder
Thanks!
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
theshackle
Aug 31, 2015 10:47 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
