C4 HD or LS1
Old Dec 16, 2006 | 09:41 PM
Jeffrey Fontaine's Avatar
Car: 1992 Z/28
Axle/Gears: 2.73's I think
C4 HD or LS1
OK guys, I have a 92 Z/28 w/ the stock 5 spoke wheels. Which brake upgrade would you recommend and why? I'm going between the two in the subject as they will fit my factory rims. I'm concerned with replacement cost/availability, stopping power, weight, and ease of installation.
I have done some searching through the board but I haven't found anything that really takes this issue head on. If I've missed a thread on this, feel free to post a link and I apologize.
(edit): I know the LS1 has a bigger piston area, but I'm not sure if piston area or rotor diameter has a bigger effect on brake torque...
Thanks,
Jeff
Old Dec 17, 2006 | 10:15 PM
WinnipegGTA's Avatar
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
The diameter would have more to do with ease of heat disapation would it not but im no brake expert though, i just know in stock form the 10.5's are no good. The thing i like about the C4HD's is the calipers look similar to our rear ones.
Old Dec 18, 2006 | 12:25 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Between the two, I went Ls1.
Most parts stores almost always have stuff for f-bodies in stock, the same cannot be said of the Y-body stuff depending on where u live.
later
Jeremy
Old Dec 18, 2006 | 01:14 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Hi Jeff. I know which direction you're heading but I'll go ahead and post up pros and cons of each setup:
13" HDs:
larger OD rotor, 13" x 1.1" thick; pad guided caliper, smaller piston area but exactly the same as 1LE calipers; same pads as '88-96 Corvette and '88-92 f-body with performance pkg; as designed, adds .500" per side to track width
12" LS1s:
Thicker 12" x 1.25" rotor, pin guided caliper design (smoother); larger pistons/bore volume; larger brake pad contact area; with larger than 16" wheels you can use a stronger C5 caliper in place of LS1 caliper, they interchange; as designed, adds .300" per side to track width
It's pretty much a personal preference thing, they are both great setups. The LS1s would compare to a Baer GT kit (C5 calipers used in GT kits) and the C4s are essentially a Baer Track kit, their most popular.
I run the HD fronts on my RS and love them, full 1LEs on my other car. HTH.
Ed
Old Dec 18, 2006 | 02:00 PM
Car: 1992 Z/28
I'm just trying to make the "right" decision first go around. As you may remember Ed, I had used a 1LE setup on my old Monte SS. It was night and day above the stock SS/Camaro setup, but it was heavy, I warped a rotor, and I couldn't get a new one without ordering it ($65/ea).
I just took a peak at the prices/availability of the C4 HD parts, and I think that seals the deal for the LS1's.
Set of Morse loaded calipers & rotors (no carriers) - LS1 = $197
-C4 HD = $296
Plus I can get the F-body stuff any day of the week w/o ordering. If I was going to spend the money for C4, I think I'd go full C5 (assuming they would fit under the rims).
Old Dec 18, 2006 | 09:41 PM
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
What about the stopping power. Any difference?
Old Dec 18, 2006 | 09:56 PM
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
-C4 HD = $296
Ebay can be your friend. Lots of Calipers on there for 99bux w/pads
Old Dec 19, 2006 | 12:13 PM
MilehighBird's Avatar
Car: 1987 Firebird Formula
Engine: 305 LG4
I got a C4HD kit from Ed and am very happy with it. I don't think that you could go wrong either way.
Old Dec 19, 2006 | 12:26 PM
Car: 1992 Z/28
Right. My quote included loaded calipers @ $115 or so, which is about what the Ebay parts would be after I waited and paid to have them shipped to me. My $197 includes the price of rotors at approx.$40/ea for the LS1's.
Old Dec 19, 2006 | 01:40 PM
ebmiller88's Avatar
I understand, you'll be very happy with the LS1s and the aftermarket can keep you supplied without issues.
Ed
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
