How do I tell if a Camaro has rear discs?
Old Jan 21, 2007 | 03:50 PM
Naga1337's Avatar
Hello
I looked through the FAQ and did a search for "4 wheel disc," but I didn't come up with anything, so I'm posting this. Is there some way of determining from the model/year/VIN whether or not a Camaro has all wheel disk brakes?
Thanks for any help.
EDIT- In the topic title and message, I meant ALL wheel disc brakes. Sorry.
Old Jan 21, 2007 | 04:01 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
I dont believe theres a way by the VIN only. If its a Z28 or IROC-Z, it may have disc brakes on 4 corners. Altho Ive seen both Z's with and without them. If its an RS, its probably drum.
Old Jan 22, 2007 | 10:10 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
Just look, if the rear brakes look like the front, they are disk. If they look like The bottom of a cast iorn pot, they are drums.
Old Jan 23, 2007 | 11:48 AM
jayhardy's Avatar
pull off the rear wheels, if you dont know what it looks like look at your fronts, if they are the same its disc, if its sealed and you cant see the pads, you have drums which have "shoes" rather than pads.
Old Jan 23, 2007 | 12:20 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Don't even need to take the wheels off to see.
Finding RPO code J65 would be the only way to tell if it had rear discs from the factory.
Old Jan 23, 2007 | 01:29 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
look at it.. if you cant tell a drum brake from a disk, then what does it matter?? almost any car can have disk brakes.. my trans am with pretty much no options, had rear disk brakes.. i had the basic options that most people want.. anyone have a rear window wiper?? i had one.. its gone now but i had one..
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
novaderrik
Aug 10, 2015 12:44 PM
