View Poll Results: Which rear disc swap do you think is the best.
C4 Corvette rear disc brakes
0%
Multiple Choice Poll. Voters: 22. You may not vote on this poll
POLL!!! What do you think the best rear brake swap would be.
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
Take a second to give me some feedback on the best rear disc brake swap would be for our cars.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
that all depends on money available and what the car it going to be used for
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
well I'm going C5 for the fronts... and I'd like to eventually get matching rears..
I should have stated that most likely all these brake setups will be used and about the same prices. So price is not really a factor. The car is mostly for street duty but I want the most braking power I can get without modifying a crap load of stuff. Basically I want to know which setup will be the best of all worlds. Weight, clamping force, most reliable, etc....
Car: Cobalt SS/SC and 88 IROCZ
Engine: 383 TPI
Axle/Gears: 3.73 Eaton Posi
here man check this stuff out! drum to LS1 setup for 200 bucks with pictures and a how to...
https://www.thirdgen.org/ls1reardisc
