ls1 upgrade!!!
Old Feb 11, 2007 | 11:40 AM
camaro_boy123's Avatar
Car: 1986 Camaro z28
Engine: 350 v8
ls1 upgrade!!!
hey guys, ive read the whole www.thirdgen.org/ls1reardisc swap info. but i have a disc rear( the old delco ones ).. does this make it easier?
also about the fronts to upgrade the fronts to the ls1 fronts i need to fab the spindles.. ed can i get some input on this? ( or anyone else that knows?)
thanks for your time
Douglas
Old Feb 11, 2007 | 03:14 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yes. I'm unsure about LS1 calipers, but 89-97 calipers are bolt-ups with the correct backing plates:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
As you see, I chose 1LE fronts as well. These required a simple spindle modification.
JamesC
Old Feb 11, 2007 | 05:17 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Glad you made it Cam boy. You might want to PM ebmiller to getfaster input. or refer to the stickies at the top of this forum. James is right about the backing plates. Changing those would allow you to run the 89-97 PBR's. However, you may experience what I did when I swapped a 3.27 88 rear into my 89 car. I had to recenter the caliper carrier in relation to the rotor. This meant adding shims on between the carrier and axle housing in order to provide the proper clearance. Something about 9 bolts with the old and new setup. I think the flange on the 82-88's was thinner that that of the 89+ 9 bolts. Anyway, other than that,you may need new ebrake cables as I mentioned before, due to the different in design. The delco's used a weighted system and a different hookup. They also alternated with one cal trailing, the other leading. Both PBR's are setup to trail. Just something to think about.
BTW, do you have a ten bolt or a nine bolt rearend? That will also determine a few things!
Will
Old Feb 11, 2007 | 05:29 PM
Engine: 350 v8
hey Will, i got a 10 bolt with disc setup right now.. its really confusing the hell outa me lol.. i want to put on the newer LS1 disc setup.. i guess i will figure it all out when i have it physically infront of me
thanks for all the help fellas
Douglas
Linson
Oct 24, 2025 02:00 PM
dusterbd
Sep 29, 2015 08:40 AM
