Delay In Brakes
Car: 1986 Chevrolet Camaro Z28/99 Aurora
Engine: LB9 5.0 TPI/4.0 V8
Transmission: 700r4/?
Axle/Gears: 2.73/3.08
Delay In Brakes
I have this delay of about 4 seconds in my brakes. When I push in the brakes it doesnt release when I let of the pedal it takes it about 4 seconds. Is this normal? Its a pain in the *** when I want to go in reverse. Any suggestions?
Re: Delay In Brakes
There maybe a year old. It was stored all winter maybe that has something to do with it?
Car: 88 gta
Engine: 350 tpi
Re: Delay In Brakes
could be water got in the system or some old varnish in the lines desolved, flush them till they are clean and see if that makes a diferance, it also could be you need to reseat the brakes after siting so long, go do bout 6 hard stops working your way from bout 40 to 5mph, all the way to 65-70 to 5mph, but dont stop in the middle get the breaks good and hot then let them cool slowley, if new fluid and rebedding the breaks dont help i cant help you.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Delay In Brakes
If your brake pedal is coming back up but your brakes are still applied (to at least one wheel) you've likely got residual pressure on that brake caliper/cylinder. Meaning the fluid is not finding an easy path back out. Usually caused by failing brake hoses as they deteriorate from the inside out. The MC can push fluid in under pressure to engage the brakes but the fluid can't get out and release the brakes. Check your flexible hoses, should be one at each front caliper and at least one in the rear.
dbrochard
Sep 19, 2015 08:13 PM
