newb question
Old Apr 19, 2007 | 10:29 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
newb question
whats all of this about using a C-clamp when you pull the calipers off your discs? or is that just for if youre leaving the lines intact and theres pressure in the system?
I took the brake line off and just pulled the caliper off and it looks fine.
I need to pull the outer bracket and pads off so i can clean them for paint, is there anything else i need to do first?
Old Apr 19, 2007 | 01:20 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Re: newb question
oh and can brake parts cleaner hurt anything in there once the pads are off? like the pistons or any of the rings/seals
Old Apr 19, 2007 | 01:39 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Re: newb question
we use the c-clip to compress the caliper piston so the new pads will fit, since they will be thicker
Old Apr 19, 2007 | 06:51 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Re: newb question
Don't forget to pop clip off master cylinder cap before jacking the piston back in though.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
