2 q's - rear disc brake upgrade 88-89 9 bolt
Old Apr 22, 2007 | 01:15 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
Ok so I want to upgrade the rear brakes on my car. Currently I have a 9 bolt rear end with disc brakes and I want to swap upto the 89 pbr style. I've got a couple questions;
1. Are the ebrake cables the same?
2. Are the brake lines the same?
So I'll be getting the backing plates, calipers and pads, 11.65" rotors. If the ebrake and brakes lines are the same, it should be a simple swap. Am I missing anything?
Thanks.
Old Apr 22, 2007 | 01:25 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: 2 q's - rear disc brake upgrade 88-89 9 bolt
No, not the same:
http://pg.photos.yahoo.com/ph/tarami...er72/my_photos
You'll need disc cables for the PBR brakes. You can use your brake lines but you'll have to cut and flare one side of them, they are slightly different. It's a whole lot easier to just install a correct new set, the money spent is worth the time you'll spend doing the work.
Ed
Old Apr 22, 2007 | 01:35 PM
Brisk's Avatar
ok thanks Ed. So is it worth the upgrade, or should I wait for a LS1 set?
Old Apr 23, 2007 | 05:24 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Here's what I did:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
Jamesc
Old Apr 23, 2007 | 12:48 PM
ebmiller88's Avatar
Personally, I recommend the 1LE/LT1 rear discs over the LS1s for ease of install and direct fit of backing plates and cables. They give you plenty of rear brake. All in all it's a personal choice.
Ed
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
