rotor thickness
Old Apr 28, 2007 | 12:08 PM
91rscamarospeed's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
rotor thickness
ok i have a 91 camaro rs and my brakes are grinding.... instead of buying whole new hub rotor combo im tryin to save some money i am a tool and die maker and i can machine the rotors myself but im quite curious to find the minimun thickness that the rotor has to be.... can anyone help me??????
Old Apr 28, 2007 | 02:30 PM
Daishi's Avatar
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
Re: rotor thickness
Mine are laying in my spare bedroom, I could measure mine up for ya.
Ok got em measured, ah the joys of the internet.
Anyways, if anything you can use it as a guide. They are exact as I could see them but by no means are they 100% accurate. I'm holding my rotor on my lap and measuring it.
And they are the exact replacement for my rear disk on my 88 IROC.
Andddd as for minimum thickness, it should be stamped on the inside of the rotor... Mine says, " MIN THK 24 3MM "
Old May 2, 2007 | 12:59 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
Re: rotor thickness
Just buy new ones, their only like $30 at any parts store. Of course you need new pads, bearings (actually install the races), seals and your done. Grand total - $100.00. Piece of mind - Priceless!
Fanatic1074
Oct 3, 2022 05:57 AM
loud91rs
Oct 5, 2015 10:05 PM
the_hamturdler
Sep 30, 2015 12:50 PM
the_hamturdler
Sep 22, 2015 02:59 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
