3rd gen open drum to 95 posi disk and LS1 brakes?????
Old May 1, 2007 | 03:14 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I have a 91 camaro with 3.42 open drum rear. I got a 95 rear posi disk with 3.23s.
Questions:
1. I got a LS1 master cylinder and a 91-92 1LE propvalve, will that combo work?
2. Will the LS1 brake setup bolt right up to the 95 rear?
3. What about the brake lines from the car to the rear and from that fitting to the calipers (axle lines)?
4. Can I put my 3.42s on the 95 posi carrier and loose the 3.23 gears?
5. Am i forgetting anything?
I wanna try and get this done in 1 day, so I wanna be ready for it.
Old May 1, 2007 | 07:26 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
Re: 3rd gen open drum to 95 posi disk and LS1 brakes?????
hey
4. If both carriers and gear sets are 3-series (or both 2-series) you can do it.
5. you'll need at least: seals, shims, and a new crush sleeve (possibly bearings). Make sure you have the neccesary tools as well.
If its your first time start early to get it done, shimming the rear is a pain in the butt, and the first time you do it only makes it worse.
I might be interested in your old rear for its spring perches and shock mounts when you're done with it. I'm planning on putting a 12 bolt rear in my car and don't want to chop up my 94 disk rear to do it.
I'm getting tired of putting gears in this weak peice of crap (on my 3rd set)
Old May 1, 2007 | 08:17 PM
krisb410's Avatar
Re: #rd gen open drum to 95 posi disk and LS1 brakes?????
My step dad will do the gear swap for me if I get everything needed. I just will take both rears to him, then when he is done, I'll have to install it on my car and hook up all the brake stuff.
I just want to get all my ducks in a row. I would like to get this done by may 13th at the latest.
ttypecamaro: If you want the old rear, your welcome to it. I'm sure you have something I need we can trade on or something.
Last edited by krisb410; May 1, 2007 at 08:21 PM. Reason: added message to ttypecamaro
Old May 1, 2007 | 09:59 PM
sounds like a plan... I still have those 3" cat backs, minus one flowmaster muffler.
Old May 3, 2007 | 01:46 PM
krisb410's Avatar
Anybody put LS1 rear brakes on a LT1 rear???????
Old May 15, 2007 | 11:02 PM
Legal Disaster's Avatar
Car: 1986 Iroc-Z
If I'm not mistaken the ls1 rear brakes will swap right onto the lt1 rear. I'm not 100% sure, but check out ls1tech.com and you should find your answer in a matter of a few minutes. good luck on your swap
Old May 16, 2007 | 04:20 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
LS1s will bolt right onto a disc LT1 rear.
Orr89RocZ
Apr 25, 2016 08:28 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
AkDrifted
Aug 17, 2015 07:45 PM
reiderz iroc
Aug 13, 2015 04:57 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
