LT1 Brake Wheel Fitment
Old May 24, 2007 | 05:42 AM
84TranzAm's Avatar
Car: 84 TA Black/ Gold
Engine: 383 With Vortec Heads
Transmission: 700 R4 Lvl2 Performabuilt 9.5 Vert
Axle/Gears: Moser 9" with 3.70
Is ther anyone running 15 inch rims on the rear of an LT1 brake set up. In the wheel fitment chart these brakes are not included and I have been reading forever and can not seem to find an answer. I am in the process of doing a drum to disc upgrade and a 4th gen rear swap in my 84. Do the calipers have to be ground down. I was thinking about going with a 15 inch rim just so I can run a thicker wall for traction. I would like to run a drag style rim. Does anyone know if DOT laws in Canada let us grind down the calipers. Thanks for any info folks
Old Apr 9, 2013 | 12:33 PM
potterc32's Avatar
Car: 1985 Pontiac Firebird S/E
Engine: 350, .5 lift cam, Holly 650
Transmission: Monster Transmission 700R4-2K stall
Axle/Gears: 4th gen 10 bolt, 3.42
Re: LT1 Brake Wheel Fitment
Did you ever find an answer? I am about to do the same swap!!
Old Apr 16, 2013 | 10:54 AM
potterc32's Avatar
Looks like the 15's fit just fine, a little room to spare!
Old Apr 28, 2013 | 06:29 PM
Intimid8R's Avatar
Car: 1986 Z28 - Factory Yellow
Engine: LG4 305 - Tweaked just a little
Transmission: T5 Manual
Axle/Gears: 10 bolt 3.73 Posi
Yes the LT1 rear brakes fit with stock 15" wheels, I'm running this setup on my car with a little room to spare
Old Apr 28, 2013 | 06:34 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I've got the LT1 brakes on my rear with stock 15" camaro wheels with no problems.
Vintageracer
Jan 10, 2020 05:33 PM
kah992
Aug 19, 2015 02:55 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
