1997 LT1 Brakes
Old May 27, 2007 | 08:27 PM
84TranzAm's Avatar
Car: 84 TA Black/ Gold
Engine: 383 With Vortec Heads
Transmission: 700 R4 Lvl2 Performabuilt 9.5 Vert
Axle/Gears: Moser 9" with 3.70
1997 LT1 Brakes
I am gong into town this week to get my bearings pressed on my axles of my Moser 9 inch.I purchase a set of LT1 brakes and am just trying to confirm on the set up. Do the calipers attach to the back side of the rear end. I seen a picture of a set off a 2001 and they were both on the front side of the axles. Could someone confirm which side of the axles the LT1 go on. Thank you
Old May 27, 2007 | 10:59 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
Re: 1997 LT1 Brakes
The LT1s, like all PBR setups from 89-97, are on the rear.
Old May 28, 2007 | 04:41 AM
84TranzAm's Avatar
Re: 1997 LT1 Brakes
Thanks for the reply bingo
Old May 28, 2007 | 06:00 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 1997 LT1 Brakes
The following pic shows a 10-bolt with PBRs:
https://www.thirdgen.org/forums/atta...s-89-shims.jpg
JamesC
Old May 28, 2007 | 01:02 PM
84TranzAm's Avatar
Re: 1997 LT1 Brakes
JamesC
Thanks James
Old May 29, 2007 | 10:39 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
Re: 1997 LT1 Brakes
I'm using the exact setup- 9" Moser with '97 LT1 PBR's. Just a caution that if you're planning to use LCA relocation brackets, they interfere with the caliper. I had to remove the giant counterweight AND grind on the LCARB to get mine to fit.
Old May 30, 2007 | 05:05 AM
84TranzAm's Avatar
Re: 1997 LT1 Brakes
Firebird 383, Thanks for the heads up. I have read of people using the relocation brackets , but what is their benefits. Are they usually only used on lowered vehicles. Thnaks for the picture . What version of break cables did you use , first or second version. Did you get to use original mounting locations or did you have to make a braket. Thanks for any info.
Old May 30, 2007 | 09:44 AM
GarageToys's Avatar
Re: 1997 LT1 Brakes
The LCARBS are supposed to eliminate wheel-hop and correct the geometry on lowered cars.
I used Raybestos PN# BC94264 parking brake cables. They were about $15 each at Rock Auto. I used the original mounting locations.
dbrochard
Oct 3, 2015 12:43 PM
New2Chevy
Sep 28, 2015 12:35 AM
L0tuS
Sep 4, 2015 11:16 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
