Spindle mods for 12" C4
Old Jun 7, 2007 | 10:52 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
I hate to clog up the boards with already posted information but for the life of me, I can't find the answer to my question and I've been searching for an hour now. I know it's been gone over, so appologies to the moderators but I can't find it so....
Can someone detail the spindle modification necessary to complete my 12" C4 upgrade. I have modified my stock hubs by removing the rotor surface with a lathe. I have installed the longer studs. I have purchased rebuild C4 Corvette front calipers and carriers. I have purchased new C4 12" rear rotors (1988). I need to purchase a set of custom caliper mounts from Ed Miller. I need to purchase the proper wheel bearings, seals and brake lines. I know there is some spindle modification necessary but what is it?
Thanks!!
Old Jun 8, 2007 | 05:45 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Re: Spindle mods for 12" C4
You do the 1LE mods to your spindles. Cut off the original caliper mount ears and the drill and tap the dust shield mounting holes for the bolts for Ed's mounting brackets.
Old Jun 9, 2007 | 05:35 PM
wesilva's Avatar
Transmission: 200R4
Thanks, Mongoose. I can handle that.
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
jdperformance
Sep 16, 2015 11:55 AM
rb85TA
26
Sep 14, 2015 10:29 PM
