Are There any conversions or kits that use slide on rotors?
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
I've been thinking about upgrading for a while and was just wondering? I've seen a few threads on LS1 conversions usings the stock hub rotors and milling the rotor part down to make just a hub? is that true? im lost
thanks!!
thanks!!
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Are There any conversions or kits that use slide on rotors?
yup thats pretty much it, plus longer studs, modifying the spindle and using caliper relocation brackets.
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
I HIGHLY recommend using someone like bigbrakeupgrade.com . You can get the hubs, modified spindles, brackets, etc from them. Quality parts. You can get them in parts or as an assembled unit. But when you install them, all you have to do is buy some LS1 rotors and slip them on. Piece of cake. And the price isnt that bad.
Also, edmiller on this site also sells components and kits. I havent dealt with him, but Ive heard good things.
But it just saves time and makes things easier. The hubs are the right size, and have new studs. Its all ready to go. Bolt on and enjoy better stopping!
Justin
P.S... Ide tell you to search some, but search is kinda screwy. Just page through the brake board though and you should find some good threads on doing the swap. Here is one.. its a long one, but VERY good information in it. Copy and paste it into your browser...links arent working either...
thirdgen.org/techboard/faq-board/183169-98-camaro-ls1-brakes.html?highlight=abs
Justin
tonys91rs
Oct 10, 2015 03:31 PM
Billy Decker
Sep 4, 2015 03:46 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
