Confused now, LT1 rear brakes on an 86 10 bolt?
Old Jul 22, 2007 | 05:30 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
I thought I understood what I was going to need to do this swap but I read a few things today and now I'm not so sure I have everything I need. I have a 1986 posi rear 10 bolt with the crappy iron caliper setup, I got a 1996 LT1 rear end complete with the brakes that's totally grenaded inside just for the brakes. I thought all I had to do was pull the backing plates off of the 1996 rear and swap them onto the 86 rear end then mount the brakes. I originally was going to do this with my 9 bolt but I read that the backing plates won't fit the 9 bolt they're different, now I'm confused because I hear that the LT1 brakes are different than the 89 + 3rd gen brakes. I suppose this is a simple question and yes I've researched all this I'm not asking for alot here just verification that I CAN swap the backing plates to my 86 rear end and swap over the brakes.
Old Jul 22, 2007 | 05:58 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Confused now, LT1 rear brakes on an 86 10 bolt?
Originally Posted by 1991CamaroRslow
I thought all I had to do was pull the backing plates off of the 1996 rear and swap them onto the 86 rear end then mount the brakes. I suppose this is a simple question and yes I've researched all this I'm not asking for alot here just verification that I CAN swap the backing plates to my 86 rear end and swap over the brakes.
You can.
JamesC
Old Jul 22, 2007 | 06:52 PM
SHEW relieved now, thanks for the verification.
Old Jul 22, 2007 | 10:10 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Rear discs from '89 to '97 are essentially the same with minor differences in backing plates some other non important stuff. Have fun with your swap.
Ed
hectre13
Dec 11, 2023 08:14 AM
midge54
Dec 27, 2019 04:14 PM
Eric-86sc
Apr 3, 2016 03:52 PM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
