Need Help hooking up emergency brake
Old Aug 23, 2007 | 03:58 PM
tigercyberslash's Avatar
Car: 1984 Camaro Z28
Engine: V8 350 ci
Axle/Gears: Posi, Disk brakes all the way aroun
Hello I have a 1984 camaro and when I bought it the e-brake didn't work, when you pull on the hand brake it doesn't feel like the cable is hooked up, and there is no stopping action at all and I have a manual so I need it hooked up.
Please if you have any advice on hooking it up or what parts you need to hook it up etc. or what I should check etc.
Old Aug 24, 2007 | 05:13 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Need Help hooking up emergency brake
The adjustment point is forward in the tunnel above the drive shaft. You may find that the cables aren't hooked up or they're broken.
JamesC
Old Aug 26, 2007 | 06:56 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Check the cables and also check to see that your rear calipers aren't frozen up, they tend to do that after lack of usage. I have the recall rebuild kits on hand for them, they have been discontinued now. If you haven't been to the dealership on the recall for your manual car, do it soon and they may still fix it after 20+ years.
Ed
GTAman
Jul 3, 2024 07:29 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
