older disc brakes, odd leak
Old Aug 31, 2007 | 01:13 PM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
hey trying to nail down a cheap fix for my passenger rear caliper.
it's leaking from the ebrake actuator arm! right underneath the big nut on the backside that ataches to the cable and has a weight on it on the opposite side of the brake.
will a rebuild take care of it, or a new caliper? trying to keep this one very cheap, upgrades can come over the winter, planning on droppingthe rear axle for a refresher, and some paint!
my pads are new and so is the caliper, oddly enough, the drivers side has no problem but we've bled the passenger three times in a month and finally found the leak.
all help is appreciated
Old Aug 31, 2007 | 03:27 PM
L69norm's Avatar
Re: older disc brakes, odd leak
Originally Posted by rockit
...it's leaking from the ebrake actuator arm! right underneath the big nut on the backside ...my pads are new and so is the caliper, oddly enough, the drivers side has no problem but we've bled the passenger three times in a month and finally found the leak...
There's an o-ring on the actuator screw that's leaking. The whole caliper has to come apart to change it. If it's new caliper, take it back and exchange it.
Old Sep 1, 2007 | 12:47 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Or you can rebuild them with the recall kits which should take care of the issue. Depending on your time needs, a replacement from an auto parts store may be what you need.
Ed
Old Sep 5, 2007 | 02:06 AM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
yea got a replacment today, core charge was more then the part! hoping for c4's soon
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
overdriv
Aug 20, 2015 03:52 PM
