question about e brake cables for drum to disk rearends.
Old Nov 9, 2007 | 04:42 PM
resop.27's Avatar
ive just installed a 9 bolt with disks and i had a 10 drum. but i cant find a ebrake cable. the one leading from the lever to where it splits for the the two? i was just wandering can a cable of a 93 up work if it has disks because i need a cable badly and ive checked all the dealerships around her and local stores? any help part numbers that stuff what will work what wont.
Old Nov 13, 2007 | 08:09 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: question about e brake cables for drum to disk rearends.
First off, what year did the 9 bolt come from and what year is your car? Your profile is blank..
I can't give you a P/N for one and I'm sure it's a discontinued part from GM. I recommend just pulling one from a junk car. The '93 cable won't work for you unless you do some fab work. Give me more info and I'll direct you where you need to go.
Ed
Frozer!!!
Jan 19, 2024 04:55 PM
Eric-86sc
Apr 3, 2016 03:52 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
