98-02 Rear brakes on my 91 RS?
Old Jan 2, 2008 | 02:05 AM
F_N_JUNK's Avatar
Car: 1991 Camaro
Engine: Morris 434 Single Turbo
Transmission: TH350
Axle/Gears: 9" Ford w/4.11's
Ok, got me a full set-up off a 2002 Camaro, looking to swap it over onto my 91 RS..... anything I should do/know before I dive in?
Old Jan 2, 2008 | 02:13 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: 98-02 Rear brakes on my 91 RS?
remove the backing plates and swap. You'll need a lot bigger rims than 15"ers too.
Old Jan 2, 2008 | 04:50 AM
F_N_JUNK's Avatar
Car: 1991 Camaro
Transmission: TH350
so a nice set of 17's should do the trick then
Old Jan 2, 2008 | 07:52 PM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
Your going to have to cut the top off your drum brake axel flange too. And drill some holes.
Matt
Old Jan 4, 2008 | 11:12 PM
hotrodhoney's Avatar
Car: I race:86' I-roc Z
Engine: 350 bored 30 over (355)
Transmission: th400 w/B & M ratching shifter
Axle/Gears: has a 10bolt (for now,will change)
You may want to check and see if the following will be able to stop the car w/all four discs,especially the bigger ones that are being put on. to do so make sure your brake booster is the right size,that your perportioning valve is enough, and that your brake fluid reservoir will handle the correct amount of fluid required of the upgrade to stop the car.
good luck,
kelly
Old Jan 4, 2008 | 11:38 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You'll need to weld a bracket to the floor to hook the e-brake cables to like a 4th gen.
Old Jan 5, 2008 | 08:35 AM
You dont need to weld the bracket to the car. You can have a custom cable made to fit. Check out the thread Hey Ed, in there youll see how to get the proper cable. Also 91/2 cars came with the proper prop valve. There was no differnce between disc and drum for those years, they were all disc valves. If it was me I would udgrade the fronts first, then the rears.
Matt
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
