front disc 83' 911 sc
Old Jan 27, 2008 | 10:01 PM
Kgreener's Avatar
I need some help. I am changing the front discs on my Porsche 911 SC 83'. After removing the old discs pads I am unable to move the inside piston inside the caliper to replace the new discs. It appears stuck or frozen. I am able to move the outside piston though and placed the new pad in place. Any advice as to why the inside piston will not move??
Old Jan 27, 2008 | 11:01 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Re: front disc 83' 911 sc
And how does this relate to a 3rd gen????
Old Jan 28, 2008 | 05:11 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Go to http://forums.pelicanparts.com/
They can help you there.
Old Jan 30, 2008 | 12:03 AM
camarojustin's Avatar
Car: 88 camaro
Engine: 355
Axle/Gears: 3.73 posi
Did you open the bleed screw to let the brake fluid out as you pressed the piston back into the caliper?
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
zayne0
Aug 24, 2015 07:22 PM
overdriv
Aug 20, 2015 03:52 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
