Trouble bleeding PBR
Old Mar 28, 2008 | 06:45 PM
TF34MECHH's Avatar
Car: 90 RS
Axle/Gears: 2.77
I am having trouble bleeding my rear calipers. I have a cup style bleeder
but I am having trouble fitting it on the bleeder and still have room for
the flare wrench. The left side has even less room because of the spring
perch. Do I have to get a vacuum style. Any ideas?
Old Mar 28, 2008 | 10:18 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: Trouble bleeding PBR
You can just open the bleeder and let gravity do it for you. You can also get a helper/friend and do it the old fashioned way.
I know what you mean about the clearance on the left, I can hardly get the rubber dust cap on and off.
I'm currently rebuilding my rear calipers since the kit is $11.50 vs. $75 + core for a reman caliper. I wire brushed the crud off and the aluminum looks pretty snazzy now. I was thinking of painting the whole caliper red, but I might paint just the iron bracket part red and leave the aluminum part alone for now.
Old Mar 29, 2008 | 09:36 AM
TF34MECHH's Avatar
Car: 90 RS
Axle/Gears: 2.77
Thanks. With gravity bleed do you just open the bleeder and wait?
I am going to try it again and see what happens. It might just take
longer since both calipers have been off for a while.
Old Mar 30, 2008 | 11:59 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Like this:
https://www.thirdgen.org/forums/atta...s-89-drcar.jpg
JamesC
Old Mar 30, 2008 | 01:18 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Originally Posted by JamesC
Yes, that looks good. Turns out that I bought some "annodizing" type paint to paint the aluminum part with. I hated the way it looked, so I painted both parts opaque red. I was thinking that painting the iron part yellow in contrast might look good too. Maybe next time.
Old Mar 31, 2008 | 01:25 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
alotta times them bleeder screws will strip you might try just bleeding it off the line
mrbird
Oct 20, 2015 03:43 AM
Lmancha96
Sep 25, 2015 08:11 PM
///DAN///
Sep 25, 2015 02:15 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
dimented24x7
Sep 6, 2015 03:51 PM
