help with rear brakes and diff swap.
Old Mar 28, 2008 | 10:46 PM
midwest's Avatar
Maybe some one can help.
I just bought a complete rear end, its borg warner 9 bolt, with disc brakes, alunimum calipers.
It came complete except for rotors and one caliper bracket, it was broken.
the guy said it was out of a 89 formula with the 5.7 tpi.
Car quest had the rotors for 17.76 a piece.
So heres my questions.
Will these fit in a 15in steel wheel? I have some black nascar style wheels.
Where can i get a the bracket.
Is is what is refered as a 1le brakes
Its it the pbr calipers?
Is this diff pretty strong? I got a manual trans and seem to burn rubber all the time.
Old Mar 29, 2008 | 08:58 AM
J.Cutta's Avatar
Car: Camaro RS
Engine: 305 TBI
Axle/Gears: 3.45
Re: help with rear brakes and diff swap.
1.Far as I know the stock 15 inch wheels will fit
2.You can find the bracket on ebay, hawks and etc
3.1LE was the front brake setup which consists of a 12 inch rotor corvette style 2 piston aluminium calipers. The reason the 89+ rear-ends are considered 1LE is because the rotors size increased to 11 inches and it recieved aluminium PBR calipers as well. Which would have matched the front setup if you had a 1LE car.
4.It is considered to be a heavy duty rear end..
Old Mar 29, 2008 | 07:20 PM
midwest's Avatar
Awesome reply
One more question, i searched ebay, and i been on hawks, but still can not find a bracket. The o e part is 10112652.
If you could, can you post a link
thanks.
edited
"he reason the 89+ rear-ends are considered 1LE is because the rotors size increased to 11 inches"
So if i find some thing labeled as 1le REAR caliper bracket. If should be the one?
Old Mar 30, 2008 | 11:57 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
PM Ed Miller. He usually has parts on hand.
JamesC
Old Mar 30, 2008 | 12:57 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Got them.
Ed
Vintageracer
Jan 10, 2020 05:33 PM
draco
Oct 4, 2015 09:25 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
E Rod
Aug 28, 2015 05:17 AM
kyleb24
Aug 15, 2015 08:24 AM
